I want to create a DVD with subtitles. I have subtitle workshop, so the subtitle format should be no problem.
I have the video encoded in mpeg2(pal standart) already & need only something, that'll put it together with audio file & subtitle file. No menu or anything else needed.
I already tried Adobe Encore DVD, but it s*cks. After 20 mins of no-problem work(having the DVD almost finished), it starts to use 100% of my CPU(while doing nothing)& I must shut it down and loose all my work.
I also already tried Ulead DVD workshop. Easy to use, working fine, but I can't find the subtitle support(although there's a note about subtitle support on their web & in the help)
PLEASE HELP. I'VE TRIED TO CREATE ONE DVD WITH SUBTITLES MORE THAN WEEK, 5HRS A DAY. WITH NO RESULT
Creating selectable subtitles is authoring so I'm moving your topic.
If you are using ulead dvd workshop you must create the subs manually, you can't import any text subs other than uleads own format(a converter may appear in the future though)
https://www.videohelp.com/forum/viewtopic.php?p=798534#798534
You can also use srt2sup and ifoedit(<---click on srt2sup for guides).
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
Creating subtitles to a DVD exported project
By aashkar in forum SubtitleReplies: 6Last Post: 11th Aug 2009, 21:52 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 13:43 -
Creating Subtitles
By bandmaster in forum SubtitleReplies: 2Last Post: 17th Aug 2008, 15:22 -
Lemony Subtitler: Creating Subtitles (Shareware)
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 17th Jun 2007, 17:59
