Results 1 to 9 of 9
  1. Hello ,
    I am using Nero 6.0.11. Has anyone a guide for backing up my DVD's using mode VIDEO DVD. Must I just Joliet, ISO Level setting 1 or 2, Character Set , Multisession Disk yes or no, Relax Iso Restrictions
    I have a HP 200j (firmaware updated)Burner and want to play DVD on my stand-alone JVC DVD player
    Can anyone help me with the correct settings
  2. the link to Polarhome is I think not Up to date anymore. I cannot open it. Any other suggestion ???
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Why bother? Use imgtools classic and DVDDecrypter. A real no-brainer - just select your sources and press Start. Perfect results every time.
    /Mats
    Apr 2003
    Maryland
    If you are using the wizard with VIDEO/DVD, that's all you need to worry about. I get 100% perfect burns with just that setting. Any problems with playback seem to always be media or media / player incompatability.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  5. Originally Posted by langstaart28
    Here's a couple of places to check out that may help out. In any event, they're good places to know about:
    Doom9.net
    and
    LordSmurf
    I've found both to be very useful...
  6. Hello, Problem is every guide is different to another. Some use Iso level 1 the other 2. Another guide use Joliet. etcc.. It is complex I donnot want to waste expensive DVD+R. I allready thrown away 12 pieces of different brand using RecordNow. I want to use NERO instead.
    Doom.org/Lordsmurf/Dvdshrink.info al uses slight differnt guides
    Please help which is the best ??
  7. I usually test everything on an RW first in order to prevent wasting good disks...
  8. Since you already know how to get into DVD Video Mode, we'll start from there.
    1. Leave eveything at default, but check Relax ISO restrictions, this will allow you to use as many characters, 64 I believe.
    2. Click on the Label tab, here you will be able to enter the title of the DVD. Also because you relaxed the ISO restrictions you will be able to type longer names, if necessary.
    3. Click on New
    4. On the right hand side find the folder with your DVD files.
    5. Select all the files, and drag them to the VIDEO_TS folder on the left hand side. Do not use the AUDIO_TS folder.
    6. Click on Burn
    You're done.
    This method has worked on over a dozen DVD players, and PS2, and X-Box, no problems yet.
