Help!
Oh, yeah, hello!!
Ok, now, I really need to know how to convert (best method)
to HEX to (i guess) decemal. i.e., in my .reg file, there's
a long string of numbers. I know that some numbers, if not
all, are pairs. I've figured this out at least (I think).
Anyway, in one of my strings in a .reg file, if I have
a number like, 00,40,1f,0e
A - does it read 0040 ?
B - what number in decimal is: 1F,0E (1027?)
I need to figure out numbers in the thousands, i.e, 1010
or 2000, 2505, or 10550?
Um, sometimes, I wont know if the value should be 00 only
or maybe it should be a pari sequence just for a certain
number pair, so 00,40 might be a pair.
I'm going at some of these number blindly in a .reg file.
I've managed to figure some things out, but I need to be
able to figure out the Hex to Dec, oh, and to do the reverse
as well. So, if I see 00,40 and if it reads 0040 I know to
put those exact same strings in the sequence, but with a
higher nubmer, say 00,47
I hope I made myself clear, if not, please let me know!
Can someone direct me here, please?
Thanks!
<font size=-1>[ This Message was edited by: vhelp on 2001-10-19 21:41:06 ]</font>
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Open up calculator in windows (Start|run and type in calc). Under calc, select View|Scientific. To do a quick conversion from decimal to hex, type in 10 and then select the HEX radio button, you shoul now have A display.
Advice needed on best conversion to MPEG-2
By am_dew in forum Video ConversionReplies: 10Last Post: 7th Feb 2012, 10:37 -
help needed - format conversion of HD captures
By Billy Bob in forum Video ConversionReplies: 0Last Post: 17th Sep 2011, 16:03 -
Replacing Quicktime header in Hex Edit
By duffbeer911 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Aug 2010, 18:23 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 13:48 -
Batch conversion of large numbers of DV-AVi to Xvid/Divx
By snehne in forum Video ConversionReplies: 2Last Post: 19th May 2009, 17:04
