i will try to make it clear, but dont know if i can...
so here it goes.
i have 2 copies of the same dvd movie.
and i need to extract the subtitles from both of them
and make a new dvd that will have both subtitles.
i just dont know what program to use to extract the subtitles
in a format that a dvd authoring program can use.
i can use dvd maestro to get the subtitles into the dvd
and author as i want.
i just dont know what to use to extract the subtitles from the dvd's in a format that maestro can understand.
can someone help ?
HELL AINT A BAD PLACE TO BE
subrip to convert to text subs and then subtitle workshop or maestrosbt to convert to dvd maestro format.
thanks Baldrick, i will let you know how it turns out
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
