...written side up? Try it.
Results 1 to 20 of 20
First try: written side down.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
same here.......got written side down and up on numerous tries....oh well, it was a good thought.
HatzLoves the funeral of hearts..... -
from a distance of 5 feet, samsung 1x beall with 3.5gb of data written on it and some six 1 inch characters of sharpie.
drop 1: written side up
drop 2: written side down
drop 3: written side down
drop 4: written side down
drop 5: written side up
drop 6: written side up
drop 7: written side up
drop 8: written side up
drop 9: written side down
drop10: written side down
50/50 -
If you want this to be scientific then you need to be a little more specific.
for example:
DVD-ROM or + or -,
R or RW.
Labels or not,
Blank or full,
What height?
Are flips allowed?
Carpet, wood, concrete, ceramic or other floors.
Do bounces count?
Do you have to redo leaners. 8) -
Try this :
1.Tape a piece of buttered toast to the back of a cat.
2.Throw cat off roof.
Observe : Cat / toast will slowly rotate inches above the ground but not touch it. !
what a crock of shit....
.....great thread
Man, what suckers
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
My cat won't stay still long enough to strap the toast on properly, any suggestions?
Nice one Holistic!
Jeex's results are actually the most scientificOriginally Posted by jeex
with 2 options (up or down) the results should be roughly 50/50 and his were -
It depends on whether the ink is still wet or not. If the ink is still wet, it will most certainly fall on the ink side just to mess up the artwork
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
And the carpet it lands onOriginally Posted by The village idiot
Why are you stealing legitimate "poll topics" from tgpo?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Oops. I meant DVD-R only.Originally Posted by fmctm1sw
DVD-RW only works that way if it's blank. -
I'm new.Originally Posted by SLK001
That just means you're not doing it right........ First you have to.... Oh, off topic, sorryOriginally Posted by pacmania_2001
If the disc is labeled (with an adhesive label), I would imagine the added weight would make a difference, but you would also have to take into account the air pressure, the current temperature, wind (if any), where you are standing in relation to the disc when it's dropped (because you'd most likely be stopping it from displacing as much air in your direction if you are right next to it), are you flipping the disc when you drop it(?), are you holding it perfectly level(?), or slightly tipped to one side(?), because if this is being held by a human hand then it's most likely not exactly level, and you can't control the fact that not all your fingers will let go of the disc at exactly the same time, which would influence the direction of the fall...
Way too many variables to make any sort of accurate prediction as to which side will land up
Amusing thread though
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Heads or Tails.........pointless!
To see, one only has to look.
To hear, one only has to listen. -
I conducted my own experiments to test this theory and after 50 drops each one landed written side down. 8)
Just to be sure I changed one condition of the experiment and again every DVD landed written side down. That's 50 out of 50. 8)
So I changed only one parameter and repeated both trials and to my amazement, 50 out of 50 landed written side up in both cases.
Can anyone explain this?
mrmungus
This is serious stuff. I think your on to something
Hi from The Land Down Under
By ScottMyob in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2011, 19:43 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 19:30 -
Question about Audio parameters to drop into Gui For DVD Author
By jimdagys in forum Video ConversionReplies: 7Last Post: 16th Nov 2009, 10:58 -
Codec drop-down lists?
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2009, 08:34 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22
Thanks for the broken DVD a$$hole!
