Hi
I tried to join 2 files .avi in virtualdub 1.5.10 but when I tried to join second file I've got this message:
VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standart CBR values during processing for better compatibility. This may introduce up to 122811 ms of skew from the video stream. If this is unacceptable, decompress the " entire" audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 130.9_+34.1 kbps)
I'm newbie and for me this is " black magic".
Can someone tell me step by step what I suppose to do to be able to join these two files ?
I'll appreciate certain help.![]()
JKoniak
Try Virtualdub MP3 Freeze. It's the variable bitrate encoded MP3 audio causing you problems.
"Art is making something out of nothing and selling it." - Frank Zappa -
Hi
I downloaded vDub-Mp3 but still I need some help.
Can someone tell me step by step what I suppose to do to be able to join these two files (to change variable bitrate encoded MP3 audio) ?
JKoniak -
I use alittle progran called Peck's Power Join.Where i got it i can't remember.Maybe CNET?
I believe Vdub requires the .AVI files to be the exactly the same. I.E. compressor, and audio specs...
If you're familiar with AVISynth, then make a script to grab both .AVI files, and open your .AVS script in Vdub..That might work out..
I'm pretty sure the mainstream $$ video editors have no problems with this issue..
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 04:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 13:49 -
Easy way to join 2+ AVI files
By AppzBeWarez in forum EditingReplies: 2Last Post: 8th May 2009, 00:48 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 23:56 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
