I am backing up a few of my DVD's with Decrypter and Clone DVD. I am trying to preserve the menus and clone DVD has this ability over DVD Shrink.
Here's the problem/question, when loading my ripped file into Clone DVD I get a compression of 50% without menu's and 46% with menu's preserved. Then I go to the next screen and remove a bunch of hte adio streams I don't want. The compression doesn't change when I go back to the previous screen even though a lot of audio is removed.
DVD Shrink was able to compress up to about 60% when I removed all the extra audio and subtitles.
I don't want to lose much quality but I feel that 46% is going to be quite noticable. What is the highest compression without much video quality loss I should go for?? Is there any way I can get a lower compression and still maintain menu's??
Any suggestions are very much appreciated. Thanks very much.
CanadianZ
Hitachi DV-P415U and a Sony CD-RW CRX120E
you wont see the difference in takin the audio out by going to the previous screen, but it will give better quality. that should be fixed soon.
Does it have similar compression to DVD Shrink??
At what compression does video quality become noticable??
CanadianZHitachi DV-P415U and a Sony CD-RW CRX120E -
its almost the same as shrink. as for video, depends on the bitrate on the original movie. higher bitrate=more it can be compressed and look good.
How can I fdind out the bit rate and what would be considered Low, average and high??
Thanks, CanadianZHitachi DV-P415U and a Sony CD-RW CRX120E -
my dvd player actually gives me the option to see the bitrate, so i could check it like that as well.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Compression questions
By ishal in forum EditingReplies: 5Last Post: 31st May 2009, 22:21 -
Questions about "Audio Compression" on digital cable box.
By Xylob the Destroyer in forum DVB / IPTVReplies: 1Last Post: 21st Feb 2009, 13:39 -
Fraps: Video Compression etc. Questions
By Tinfoil in forum Newbie / General discussionsReplies: 25Last Post: 16th Jan 2009, 15:47 -
clone dvd 2
By fitos in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 18:16
