Well I have about a 3 minute mpg movie file that i just got done caputuring. The capture is great, nothing wrong with it. But when I go to edit it and take out parts I do not need and then complie it or render it, the finished product turns out very badly, very slow and also looks like many frames are dropped out. Anyways i was wondering how I can fix this? Also I was downloading stuff on Kazaa, could this effect the quality? Let me know, thanks.
Also I was download on Kazaa, could this effect the quality?
a cabbage leaf in the garden. I'm still looking for the Oracle to find
out for sure. -
Anyway, MPEG is not the good format to use in Premiere. AVI is best for editing (this goes for a lot of different video editors). I would suggest converting the MPEG to an AVI file first. As far as choppyness goes/poor quality/etc... this could be because Premiere doesn't like the MPEG file. Depending on what size you render the file to be, it might not display ok on your computer, but might display fine on a TV. For example, I was exporting some movies as 720x480, and they barely played on my computer (very very choppy, looked like dropped frames, etc...), but when sent to tape and played on a TV, it played ok.
Hope this helped a little. -
Hi nutt318,
I've not used it myself coz I edit AVI then produce an MPG from that. But I've read on numerous occassions that Womble MPEG VCR seems to be able to edit MPG without any problems.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Adobe Premiere Elements 7 DVD Creation Quality Issue
By robvs in forum EditingReplies: 32Last Post: 20th Nov 2013, 10:07 -
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 15:34 -
Quality problems on Adobe Premiere Elements 9
By inimitable in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2011, 05:56 -
Adobe Premiere Deinterlacing/youtube/HDV quality problem
By qatzo in forum Newbie / General discussionsReplies: 21Last Post: 4th Jun 2011, 13:12 -
Rendering with Adobe Premiere Elements decreases visual quality
By AuditSup in forum Newbie / General discussionsReplies: 17Last Post: 27th Mar 2010, 12:37
