Can someone translate in noob english please:
-pri / -sec: Here you specify whether your drive is connected to the 'primary' or 'secondary' IDE-controller on your mainboard.
-mas / -sla: Here you specify whether your drive is connected (configured by the jumper) as either 'master' or 'slave'.
I have an external NEC 1300A dvd burner, which one would it be classified under?
I am assuming you're in your Bios and that is where you got what you want translated.
Your motherboard, that big circuit board with the processor and memory attached, has two 'IDE controllers'. Each IDE controller can connect two two devices. What I mean by devices, Hard Drive, CD-Rom Drive, DVD Drive, DVD Burner, etc. So you can have a total of 4 devices.
As an example, typically a store bought computer will usually have the hard drive connected to Primary IDE, and a CD Rom to the Secondary IDE.
This leaves room for two more devices. Lets say you buy a DVD burner. You have the option of connecting it to the Primary IDE controller, where your hard drive is connected, or the Secondary IDE controller, where you CD Rom is connected.
I would chose the Secondary controller, as I don't like anything attached with my hard drive, unless it's a secondary hard drive.
Because I now have two devices connected to the Secondaty IDE controller, I need to designate one as the Master and the second as the slave.
This is done by moving the jumpers (the little plastic piece) on the back of the device. The link below is an example using a second hard drive:
http://support.wdc.com/techinfo/general/jumpers.asp
If you set everything to Auto the Bios will figure out where everything is connected.
Looking for an explanation of strange behaviour
By Duwgati in forum Authoring (DVD)Replies: 6Last Post: 29th Jul 2011, 08:03 -
Codec Explanation, which is best for this scenario ...
By andrewbutkus in forum Video ConversionReplies: 30Last Post: 1st Sep 2010, 11:15 -
Explanation for Samsung Burner Errors
By Seeker47 in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jul 2009, 12:16 -
Explanation of DVD Space Requirements ?
By mbluett in forum Video ConversionReplies: 22Last Post: 4th Mar 2009, 14:35 -
Newbie needs explanation on film frame rate
By holeepassion in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2008, 01:29
