with TSCV I have made a chapter on my 40 minute mpg for 22:13 and I create the Cue/Bin file and burned it correctly but when I put it in my dvd player when I press the next button to go to next chapter it only goes to about 1:30.
Anyone got any ideas?
Thanks.
Are you completely sure you put in the right time in the right spot in TSCV. In some slots it goes by frames and seconds. This could be the problem.
when your done adding your chapter times, you have to go back to the settings menu and tell it where to go for each number and next push
did you do this?
lemme know
just check the XML code manually. the reference (probably in the sequence section) should be in seconds.
22x60=1320
1320+13=1333
so it should say 1333.0
AVStoDVD Chapter Problem
By adyf in forum Authoring (DVD)Replies: 11Last Post: 21st Dec 2010, 15:03 -
mkv chapter file problem
By Bully9 in forum EditingReplies: 12Last Post: 22nd Mar 2010, 19:06 -
Muxman problem with chapter times
By lordretsudo in forum Authoring (DVD)Replies: 12Last Post: 9th Jan 2010, 08:52 -
VOB2MPG Chapter Extraction Problem
By murray666 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Oct 2009, 04:14 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51
