My problem is that I cannot make DVD's with wide screen format by using NVE2. I recently got Nero 6 and I am very happy with the overall function, except for a wide screen problem with NVE2.
When I add a wide screen format videofile (.avi 720x576 1.422 pixel aspect ratio - made by Premiere 6.0)it seems that NVE2 converts it to 4:3. The setting in NVE2 is 16:9 and black areas fill out the remaining width of the video that seems to have changed to 4:3 format.
If I capture the DV directly from my DV camera, using NVE2, the 16:9 wide screen format goes in as it should to NVE2.
Now I suspect that some of you will say that Premiere is the propblem but I do not think so. If I play the avi file (that I were not able to down load to the correct format by NVE2) by using window media player or nero's player it works fine showing the 16:9 format. So something happens during download of that avi file to NVE2.
Can someone explain whats wrong and how to fix the problem?
Paul
from Sweden
.avi data:
Compression: Microsoft DV(PAL)@100%
Image Size: 720 x 576
Pixel Depth: 24 bits
Pixel Aspect Ratio: 1,422
Frame Rate: 25,00 fps
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
