I encoeed some mpeg 2 elementery streams with tmpgenc, and they do not have a sequence header for the gops.
Is there a setting in tmpgenc I missed? All the files are bunk.
Will restream repairt hem for me, and what setting do I have to make so they will hav a valid sequence header in the first place?
There is a setting under GOP structure that should be selected - "output interval of sequence header". Select "1".
To add sequence header after encode https://www.videohelp.com/forum/userguides/126292.php -
You're my hero thx so much!
this was an avi capture huffyuv, an when I got my good elementery stream made, i deleted the source!
I read and saw what I did wrong so i know for the future,and I tried restream but it can't do it.
A simple merge cut did the trick.
BTW the link you posted was for vcd, but it worked for my mpeg 2 files just fine. -
Glad it worked for you; tne "merge and cut" is a neat little maneuver and has saved me a number of times.
Thanks for pointing out that the link referred to VCD/Mpeg1 - I forgot to mention you needed to change Mpeg1 to Mpeg2 - obviously you it figured out. -
Hi duhmez,
I find this guide:
http://dvd-hq.info/Compression.html
...very useful for pretty much all of the settings in TMPGEnc (including GOPs). It may seem daunting at first, but that's only coz there's a lot there and it's well explained detail.
Read it carefully, as there are some useful pointers that can be missed if you skim read.
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I always load the dvd template when I make a DVD and then I only make changes to stuff that I know doesn't effect the dvd standard...or else I read about it first.
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
Sin City - movie over 50 seperate m2ts files - not all in sequence.
By Z.Sath in forum Blu-ray RippingReplies: 5Last Post: 11th Jun 2009, 15:45 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Header Information in Video Files?
By Javad0g in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd Apr 2008, 14:10
