Howdy All,
Just wondering if anyone know's how to use MyDVD to burn the files that DVDShrink has createdI'm sure I must be a dumbass and doing something wrong as I can't seem to get it to work. I've been using Nero Burning for doing the burning part of the sequence and it's been dead simple to use and I got great results, but the trial period is over and I don't want to spend the $$$ if I can do the burning in MyDVD. Has anyone been using the programs I've mentioned and if they have could you give me the quick idiot's guide to burning Shrink files in MyDVD
Thanks in advance,
Max
You can't import VOB's to MyDVD.Don't be cheap,go and buy Nero or RecordNow Max.Use Burnatonce or use ImgTools classic and DVDDecrypter in the mean time.
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
trying to put VCD files on a DVD with MyDVD Express
By curt1sw in forum Authoring (DVD)Replies: 7Last Post: 15th Nov 2007, 14:42 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 13:17
