First post.
Sorry if this is in the wrong forum.
I'm hoping someone can offer some insight.
Recently got a LiteOn LDW-411S.
Latest firmware updated(last two updates actually).
Running XP Pro with all updates.
Install went fine and I've burned several backup movies and data dvds onto +R disks using Nero 6 and Copy2DVD.
The problem is that I can't get DVD+RWs to format even, let alone burn, using either Nero nor Copy2DVD.
Neither the DVD+RW that came with the unit nor any of the Memorex 3-pak I purchased.
I even updated WNASPI directly from Adeptec to no avail.
This is part of the LOG file generated by Nero when I tried to burn a data file to DVD+RW:
Any help would be appreciated.2.2.2004
ISO compilation
11:26:58 AM #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:26:58 AM #2 Text 0 File Reader.cpp, Line 118
Reader running
11:26:58 AM #3 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
11:26:59 AM #4 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
11:26:59 AM #5 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286143 (508:01.68, 4465MB)
11:26:59 AM #6 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
11:26:59 AM #7 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: LITE-ON DVDRW LDW-411S, Media type: DVD+RW
Disc Manufacturer ID: PHILIPS, Media Type ID: 041, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
11:26:59 AM #8 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
11:26:59 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286144 (2286144) = #2286144/508:1.69
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286144 blocks [LITE-ON DVDRW LDW-411S ]
11:26:59 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON DVDRW LDW-411S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682022912, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286144 | lead-out | 1 | 0x00 | 0x41
11:27:00 AM #11 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
11:27:00 AM #12 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
11:27:00 AM #13 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
11:27:00 AM #14 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5,520 KB/s)
11:27:00 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:27:01 AM #16 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 01 50 48 49 4C 49 50 - 53 00 30 34 31 00 39 23 ..PHILIPS.041.9#
00 9F 7C 5C 02 28 00 9A - 7E 70 02 28 00 A0 7B 68 ..|\.(..~p.(..{h
02 28 04 04 20 E0 00 F0 - 00 00 00 00 00 00 00 01 .(..............
11:27:01 AM #17 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 14:20,178 (860178ms) -> OK
11:27:01 AM #18 Phase 98 File dlgbrnst.cpp, Line 1800
Start formatting disc before burning
11:27:01 AM #19 SCSI -1065 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 5, TA 0, LUN 0, buffer 0x02D37000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0x04 0x11 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x20 0x00
11:27:01 AM #20 Phase 101 File dlgbrnst.cpp, Line 1800
Formatting disc failed
11:27:01 AM #21 Text 0 File DVDPlusRW.cpp, Line 564
Start write address at LBA 0
DVD high compatibility mode: Yes
11:27:01 AM #22 CDR -1065 File ThreadedTransferInterface.cpp, Line 1573
Invalid command
11:27:01 AM #23 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1573
Could not perform start of Disc-at-once
11:27:01 AM #24 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
11:27:01 AM #25 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\atapi.sys': Ver=5.1.2600.1135 (xpsp2.020921-0842), size=87040 bytes, created 10/24/2002 2:59:48 PM (Adapter driver for src)
Brett
Try a different ide cable maybe.If anyones interested there's firmware that will change your 4x liteon drive into a 8x dvd+r writer. If interested pm me.
Bump.
Has no one seen or heard of this problem before?
The weird thing is that I can burn +R's no problem.
I just can't get the +RW's to format.
brett -
Get rid of InCD, reboot, and your +RW problems will disappear.Originally Posted by brett_t
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 21:59 -
Archived unfinalized DVD-RWs--can i play them?
By mpmp0 in forum Newbie / General discussionsReplies: 23Last Post: 30th Aug 2008, 23:31 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 1st Oct 2007, 00:49 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 14:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 13:51
