Anyone know if these are able to do analogue to dv pass thru? TIA
I had a Sharp DV cam that would record analog, but no pass through. I don't think the new units even have analog recording anymore. As far as know, pass through is limited to some Sonys and Canons.
Well that sucks. I was thinking about getting the Sharp VLZ3U and using it like a capture device.
Yes, it does suck. Seems like pass through is getting harder to find. The lower end Canons still have it; the lower end Sonys do not. My current camcorder (a Panasonic) will record to tape from analog, but that makes for a time-consuming, two-step process. I could get a new DV cam, but my I like most of the features on my Panasonic. I'm thinking of a used digital 8 model that has pass through. This will do the real time conversion I seek and let me play my old Hi8 tapes as well. I do have to be careful as not all the D8s have passthrough. All the 2000 units did, but since then the entry level units have not. If you are looking for a reasonably priced DV with pass through, you could go for the Canon ZR's, but I think last year's models are better than the new ones. The current crop has no microphone jack and tape motor noise can be a problem.
My wife's Sharp camcorder has pass-through. It's a VLZ-N105 or something like that. It's about three years old, and I imagine if you can still find one it's got to be pretty inexpensive now.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Do all DVD players deinterlace DVDs made from mini-dv camcorders?
By granturissimus in forum Newbie / General discussionsReplies: 12Last Post: 16th Jan 2011, 21:01 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18
