A question. Is PAL and NTSC encoding something different to regions? If I make my player regionfree will it play everything? PAL and NTSC or will it only play PAL?
Ur just jealous coz the voices r talkin to me
Regions and PAL/NTSC are different issues. A Region free player will not necessarily play both PAL and NTSC, though the odds are in your favour.Originally Posted by browser
Is there somewhere to download NTSC samples or sample DVD's of different regions? e.g a sample of a region 1 NTSC DVD?
Ur just jealous coz the voices r talkin to me -
PAL and NTSC are colour systems. They're completely non-existant on DVD. However, the two systems are associated with different resolutions and scan rates. "NTSC" DVDs are designed to be easily output as an NTSC signal, and "PAL" DVDs are designed to be easily output as an NTSC signal. MOST players will work fine (oddly, cheaper ones more so) taking a PAL DVD and outputting NTSC (and vice versa), but the quality won't be as good as the "right" DVD. This is where a multiformat TV (which most PAL country TVs but few NTSC country TVs are) that natively handles both really helps. Region coding is completely unrelation. It's an artificial limitation, unlike a standards barrier. And region DVD can be either format. A region 1 DVD can be PAL for example. And a region 1 only player with PAL/NTSC convert can produce NTSC from an all-region or region 1 (rare) PAL DVD. So, PAL/NTSC's the TV standard. Region coding is the motion picture industry's attempt at international trade barriers, and to hang onto an outdated system of differing regional release dates and rightsholders.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Various Regions PAL DVD's
By dblan9 in forum Authoring (DVD)Replies: 6Last Post: 11th Mar 2010, 18:10 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
