OK...so I'm using Gordian Knot, and after you rip the DVD to your HD you need to run DVD2AVI, fine, it's a 5 VOB movie. The thing is once I go to "Save Project", it only does the first VOB, is that normal?
There is a button called "ADD" in the "Open-File" dialogue. When you have at least two files loaded, it will automatically load the rest of your VOB's if they are sequentially numbered.
It assumes that if you load; D:\Test_01.vob, and D:\Test_02.vob, that you most likely will want to load them all. Evey VOB in that same directory, that have the same base name "Test" will be loaded.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
