Hi
I am very new to all this and it is a tad confusing, but any plain and simple answers would be apreciated.
I have some Mpeg-1 files, 448x336, 29.97fps, 1150kbps. I would like to convert these to a DVD compliant file type to enable viewing on a standalone player.
I have been using TMPGenc to perform some test runs and am reasonably happy with what i am doing (reasonably - definately not confident!).
I would like to ask what you think would be the best resolution / bit rate to encode to.
Is it better to reduce than increase resolution - which seems to have been suggested in other threads, or would the best bet be to simply resize the Mpeg-1 to 352x240 and then recode the audio to 48khz.
Basically i would like to view these files on a DVD to the best quality (given the source) without bloating the size of the files too much.
Thanks for any suggestions
there is an old saying on the board: can't polish a turd. Basically, you NEVER want to upsize the bitrate or resolution (or audio for that matter) when doing a conversion. No matter what conversion you do, there will be A quality loss.
The 2 solutions that I see would be to:
1. make a VCD-DVD -Baldrick has a guide using Moviefactory2 that shows you how to do this
2. convert the VCD to dvd resolution, however, keep the VCD aspect ratio of 352x240-there is a guide called something like "convert low rez 240x240 avi" that will give you the concept to do the conversion. Basically, will encode the avi file at 448x336 or , but will have the aspect ratio of the dvd file of 720x480 (will still need to upsample the audio to 48mhz).
Let me know if you need more info. -
Cheers Macleod
I will give both of these a go and see which one i like best, or which one gives the most shiny turd!
[/code]
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 08:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 18:44 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04
