I have some tv programs on VCR tapes that I have burned on to DVD but im having a problem seperating each one so I have the option to skip around from one to the other.
Ive used Tmpge DVD Author and have made seperate titles for each program but they still seem to run together and dont give me the option to jump between programs.
I guess what im trying to say is, I would like to make it like a music CD where you can skip between tracks but in this case, programs.
Any info is appreciated.
I'm a victim of circumstance
Each of your tv program mpg files need to be entered into TDA under separate tracks.
If the programs are all in one mpg file, use TDA's edit function to associate the appropriate clip section with each track.
Check your "menu display settings" in TDA to get desired track play options.
Detailed instructions/explanations for above are included in TDA's help file.
Use a rw disk for initial test burns to avoid coasters.
Good luck. -
TDA???
Im such a newbie, in not sure what that is.I'm a victim of circumstance -
Duuuuuuh me. LOL.
I will try it out. Havent really researched the program that much yet.
Wasnt sure if it was TDA or my Nero I used for burning, in order to get the results i wanted.
I will try out what you recommended.
ThanksI'm a victim of circumstance -
Gotta love these forums.
I did it, I did it.
I was able to put three different titles on my DVD and able to chose which show I wanted to watch first.
Of course doing some reading about the author program I was using sure seemed to help.
Thanks also to the ones who put me in the right direction.I'm a victim of circumstance
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 15:51 -
Two OS on seperate HD update/boot?
By neworldman in forum ComputerReplies: 1Last Post: 25th Jul 2010, 18:53 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
Two seperate VLC playback issues
By ecc in forum Software PlayingReplies: 13Last Post: 25th Sep 2009, 07:36 -
Help.Winavi converts to 2 seperate folders
By hitmanhill in forum Video ConversionReplies: 0Last Post: 7th May 2007, 02:26
