  1. I have Piglets Big movie overhere.
    It's a 2-layer and I want 2 convert it 2 a single disc movie.
    I know how 2 do a movie-only rip, I can re-encode and the things, but with this 1 I want 2 do something else.
    The DVD starts with a Disney trailer with new movies.
    I want 2 get that out.
    After that, there is a language selection.
    I want 2 get that out as well.
    After that start the menu in the chosen language and that's the part I want to keep.
    So what I want is everything after the languageselction.
    There is also a DVD-Rom part on the DVD, but there is no problem in leaving that out.
    What program's do I use (DVDstripper?, Nero-reencode?) and how do I do it?
    thnx
    Dec 2002
    2 is a number and not a preposition.
    Did you even try to read anything?
    There's a number of programs you can use. DVDDecryptor/IFOEdit will work, but that's beyond your skillset. DVDDecrytptor/MenuEdit can do it also.
    Disney movies are notoriously short, and if you remove all the extras usually run well under 4 GB. What purpose does a menu serve if you have dropped the subs/alternate audio?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. I have read a lot on this forum and it dazzles me.
    So many solutions.
    And why the menu's
    Cause there are a lot of extra's on this dvd and I think I can fit al the extra's and the movie on a dvd.
    grtz
  4. Originally Posted by Gazorgan
    The main reason I like to keep menus is for the Chapter selections. Not only can I jump to a certain chapter, I can know what the chapter's title is. This is great because, I'm too lazy to come up with a DVD case label with the chapter titles on them. All I do is slap a brief description hub label on them.
    If I didn't have a visual chapter selection menu, then I would feel like I'm going back to VHS days.
    Besides, when you're at a restuarant, would like to see a visual of what's on the menu or be verbally told what the menu is?
