  1. Hey people.
    I hope someone here can help me! I've got an xvid, width is 592 and height 320 pixels, audio format is mpeg layer 3. I usually use moviefactory to burn my dvds but it can't handle the ratio, it makes everything go full screen from what people have told me i need to use TMPGEnc to convert it, does anyone know what settings i should be using??? it also seems to crash lots when i load my movie, is this a known fault or just me being a fool?
  2. mrfoo_uk,
    Take a look at the third post, by Hooky. Set your TMPGEnc up like that, and it should cure the crashing problems.
    https://www.videohelp.com/forum/viewtopic.php?t=189579&highlight=xvid+reader+priorities
    When converting your XviD to DVD using TMPGEnc, you should have the source aspect ratio as 1:1 and in "Other Settings" under "Advanced", you should set the video arrange method to "Full Screen (Keep Aspect Ratio 2)". This is what I do and it seems to work.
    Hope this helps,
    CobraDMX
  3. Thanks Cobra
    I think its worked!!!! just need to burn it now
  4. Member Sakuya's Avatar
    Dec 2002
    What's the difference between keep aspect ratio and keep aspect ratio 2?
  5. I have no idea - I'm sure there's only one way to keep an aspect! 2 has always worked, I have always used it....
    CobraDMX
