Sorry for my english,
I have converted an AVI to DVD.
I have used FFMPEGX and presets DVD
Authorising with Sizzle and burning with Disk utilities of Panther
I have burned an DVD+R
This DVD work very good in PC, MAC, but not work in my dvd player Philips Q50.
In the dvd player, video and audio is perfect, but the reading is ok few seconds, stop and rewind few seconds and repeat.
After more minutes, no audio.
Help me?
jccGuest
jccGuest
Are you sure?
A DVD+R created with my holidays videos (imported with Imovie and encoded by Idvd) is perfect on the PC, MAC and DVD Player Philips Q50
Only the AVI file (DIVX) converted with FFMPEGX and Sizzle, burned with Utility Disk of Panther do'nt operate perfectly.
I can't understand it and especially i don't know what to do.
aascudieroGuest
I had the same problem and took his advice, and it created a playable MiniDVD, however it didn't create the AC3 Audio stream. After reading the on-line docs, discovered ffmpeg could only handle AC3 so I recompressed, and now it's just hanging here.
The progress window currently says...
Encoding started on Mon Feb 16 14:50:20 CST 2004
Input #0, mov, from '/Volumes/BigBertha/BTEATM.mov':
Duration: 00:04:39.5, bitrate: 30308 kb/s
Stream #0.0: Video: dvvideo, 720x480, 29.97 fps
Stream #0.1: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Output #0, vob, to '/Volumes/BigBertha/AABteatm':
Stream #0.0: Video: mpeg2video, 720x480, 23.98 fps, q=2-15, pass 1, 4000 kb/s
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Now I'm just waiting here twittling my thumbs. My hard drive is doing nothing, the progress meter is still saying 0% and it's been over an hour on this 5 minute music video.
If IDVD uses PCM Audio, can I just passthrough the stream on my original DV file and avoid all this hassle? I don't care if the audio is compressed, it actually might be better.
also, can I add multiple channels like commentary and such on supplemental tracks?
Thanks.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
Issue getting burned dvd-r to play in Sylvania portable dvd player SDVD8727
By deviant_delusion in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2010, 19:02 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 13:56 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
