I have made SVCDs from divx files which were in 480x480 resolution or better, but make xvcds if the divx resolution is less than 480 x 480.
If the resolution of the divx file is less than 480 x 480, how will the svcd look? Will I be better off making an xvcd? Thanks
Raz
yep. better off making an XVCD, because it wont look good if you stretch the resolution. it depends. If your divX is say something like 640x352 then use SVCD, but if its 352x240 then dont. i make SVCD's out of all my DVD Rip's and the vertical resolution is sometimes below 480 but it still turns out good.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 19:09 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 11:51 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
