Very familiar with tmpgenc for VCD and just got a DVD burner. Few quesitons.
When putting a VCD file on a DVD the only thing I need to change is the audio. It seems tmpgenc DVD author does this automatically when adding a vcd compliant file to a DVD, is this right?
Doom 9's SVCD header trick seems to work to put a SVCD compliant file on a DVD for me. Is there any difference here and if re-encoding an SVCD file to DVD whats the best setting? I assume no need to up the bitrate since it's the same codec, but maybe if increasing the resolution (if is this even advisable) I should?
Most importantly, I know there is no direct correlation b/t a Divx, Xvid, etc. video bitrate and an mpeg-2 when re-encoding for a DVD, but is it the same for the audio? I know there are different audio codecs in those, but if encoding to layer II with tmpgenc, what is the normal target audio bitrate, or is it totally dependent on the source? Any agreed upon default?
Results 1 to 1 of 1
A few questions about bitrate,codecs and virtualdub
By alibaba12 in forum Newbie / General discussionsReplies: 21Last Post: 5th Jan 2012, 17:30 -
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 16:46 -
VHS to DVD - 3 questions (encoding & bitrate)
By spup345 in forum Capturing and VCRReplies: 21Last Post: 17th Sep 2010, 21:39 -
Audio bitrate challenges when converting to DVD format
By Mr Davo in forum AudioReplies: 3Last Post: 27th May 2010, 21:45 -
Questions about video resolution, and bitrate
By jay_lubb in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2007, 14:46
