i want to know how to rip(can i use any old dvd ripper) a dvd that is pal 0 and burn it as a regular us dvd, ntsc i think thats the name? any help is appreciated
in dvdshrink it says region free, could that do it?
my aim is vi0lentjuggal027
not exactly an easy question per se. Sure you can rip using any dvd-ripper, and burn away, will it work? Probably not, Pal is 25fps 720x57(6?) and NTSC is either 23.976 or 29.97fps 720x480.. Some dvd players can play PAL just fine, most can't.. test on a RW first, otherwise do a search for "PAL to NTSC conversion".
i've never done one personally, but there are some good guides around that explain it pretty step-by-step. -
would this be one of the guides that would do it? https://www.videohelp.com/forum/userguides/166237.php
my aim is vi0lentjuggal027 -
That would probably work, but it looks geared more towards SVCD, just whenever you see anything about resolution you would use 720x480 instead of 480x480, and a larger bitrate.
And offtopic, but, see you at the gathering Juggalo.
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 05:02 -
qustion about Windows startup error
By jimdagys in forum ComputerReplies: 4Last Post: 18th Apr 2008, 05:57 -
Qustion Dvd Player - Pioneer Dv393
By zaptos in forum DVD RippingReplies: 2Last Post: 28th Oct 2007, 08:26
