  1. I'm sure this has been asked before and answered but I have Super Bowl Commercials I want to put in DVD-R format that are in MPEG format now.
    Any idea steps?
    Verbatim VBTDVRW1AR DVD+RW/R
  2. try using TMPGEnc DVD Author
    -start new project
    -add files
    -create menus if you want
    -output the files to hd
    -burn new dvd files.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If they're DVD compliant then "Author" them and burn.
    If they're not then you need to "Convert" them to compliant mpeg then author and burn.
    Not sure? Check them with avicodec and check the "What is DVDR" and newbie sections.
    All the above are sections over there <-<-<-.
