When converting divx to mpeg-2 (svcd or dvd) what bitrate is needed to keep the quality? Is it really necessary to encode at 8000 kbits/s when converting divx with a bitrate at e.g 800 kbits/s?
The bitrate of a divx doesn't directly relate to the bitrate of an mpeg, they use different types of compression. For best quality always use the highest bitrate possible and higher resolution needs higher bitrates... so DVD res. needs higher bitrate than SVCD. You need to decide what bitrate looks good to you as everyone has different levels of tolerance. Hope that helps a bit.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks. I'm learning new stuff every day
I've experimented with different bitrates and I can honestly say that I don't see any quality loss from 8000 kbits to 3000 kbits when I convert a DivX movie to MPEG-2. Thats why I wonder if maybe the quality can't get any better when the bitrate passes a certain point because the movie can never be better then the source, and the source in this case lost a lot of quality when it was encodet with DivX and that's not coming back when you convert to MPEG-2 no matter how high the bitrate is set. Do you grasp my way of thinking?
What's the compression ratio for MPEG-2 compared to DivX/XviD? -
How long is a piece of string?? In my own experience I would say divx/xvid will compress down to 1/6th the size of mpeg2 (for same quality and res) however sometimes you can get 1/12th and still have reasonable quality (with lower res). YPYMAYTYC.What's the compression ratio for MPEG-2 compared to DivX/XviD?Corned beef is now made to a higher standard than at any time in history.
[quote="RabidDog"]
Funny
I consider myself as a newbie so please don't tear me a new one if I say something stupid guys
I have no idea what YPYMAYTYC means... -
You're right on with that observation. Beyond a certain point the difference is very small. What that point is depends on the source (like a crappy divx or a high quality DVD), your encoding method (CBR or VBR) and the resolution that you choose for your mpeg (VCD,SVCD or full DVD).Originally Posted by Mozz"Art is making something out of nothing and selling it." - Frank Zappa
I don't either but I can guess. You pays you're money.....Originally Posted by Mozz
zippy gets 10 bonus air miles. you pays your money and you takes your choice.
I would agree that there certainly is a maximim bitrate beyond which no improvement is possible, I would guess 1/3rd the size,(mpeg2 to mpeg4) but in my experience the dif between say 100% quality and 90% will be unnoticed by the average viewer, whilst making a big dif in the filesize.Corned beef is now made to a higher standard than at any time in history.
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 21:35
