  1. I have ripped about 300 movies from dvd to mpg. I use smart ripper, dvd2avi and tmpgenc. I ripped a dvd today that is giving me problems. I have great vob files. (that I have checked out by renaming them to.mpg) in order to see that I got them ripped out completely. (each vob/mpg file plays fine. I renamed them back to .vob and run them thru the dvd2avi program and am getting my usuall .d2v file and ac3 wave. I check the wav and it plays fine. Then I load the d2v file and the wav files in tmpgenc and encode as always. The end result is a great picture with a NO sound what-so-ever on the whole movie. I double check to see the wav is staying loaded in tmpgenc and it shows that it is there and encoding it also. I Have a total file size of 783mgs. so I know that sound is there or believe it to be. I have checked out my plugins and codecs and all are working fine. I thought it was something with my set up and procedure, so I ripped another dvd the way I have described above and that dvd worked fine with a great sound quality .mpg. This tells me that I am doing things ok and that there is nothing wrong with my choice of programs /codecs to rip with. So I went a step farther and tried to rip the problem dvd with , herosoft/ dvd x copy/ vcd easy/ and even dvd shrink. I get the same problem with any of the programs I try. NO sound. Yet the sound is there when I que up just the sound file (wav). Someway I am losing the sound in the encoding part of this. Does anyone have any suggestions/ codecs to try/ different program. or something I might have overlooked. The problem dvd is The osbournes season 1 uncensored.dvd
    I am open to try just about anything to get this now as it becomes an obsession with me when I can't get them.
    Thank you all for taking time to read this, I tried to give you all the info on it that I have and what I have tried.
    I hope to hear from some of you great rippers out there soon.
    Thanks Modartist
    Modartist
    Some are born to rule the world. to live their fantasies.
    While most of us just dream,
    of what we would like to be.
    Apr 2002
    The State of Frustration
    Original video, is it in strereo?
    Hello.
  3. yes the orignal sound is stereo surround sound. I am trying to get it to 44khz stereo 64kbps layer II
    Modartist
  4. Are you ripping the right audio track, because some movies have a silent audio track on them.
  5. sorry, I just saw you said the audio wav played fine.
    Maybe try loading the wav in an audio program like goldwave, and then save it as a new wav file.
  6. I am ripping the right audio track as it plays fine by itself, I am getting track 1 for english. That is a good idea though, I will try goldwave and see if that helps out saving as another type of .wav. thanks for that suggestion .
    Mod
    Modartist
