r there any video capturing kits.that allow u to "PAUSE"recordings.![]()
Like for instances..ur recording a tv program..but when commercials come on..instead of stop capturing....u can just pause....and when movies back on..comtinuing recording..where u left of.![]()
are they any that can do that?..
if so..please let me know..i might sell mines..and buy new one.![]()
Results 1 to 14 of 14
thanks ive just downloaded that....
but i cant seem to get it working..this message comes up...
"Cannot set the video format correctly..Please select another format/size,
Please try to select another driver Mode/Video device in option menu," -
yay!
its working now!!!
but damn!..i still have the same problem../the picture scrambles and flickers..(i wrote this in another post today)
https://www.videohelp.com/forum/viewtopic.php?t=203622 -
Im using video composite..
-the scart lead from video..& phono/video/audio imputs on the other end.
-That winpro softwares great...
..Only problem is..i have to pay $30 & register
jk...Thanks gll99
......thanks for the link....eventually ill register..becus..using pause & record is essiental part of my recording/capturing.
Seems to me that using a Pause function to edit out commercials is stepping backwards a few years. Why not just capture everything and then edit out the commericials. There's a number advantages to that- you don't have to sit there with your finger on a pause button waiting for the next commercial. You don't have to worrying about being 10 seconds late hitting pause when the commercial starts- or worse- being 10 seconds late starting again when the commercial is over.
Although now that I think of it- there is a video capture kit that allows you to Pause recordings- it's called a VCR. -
Thats a good idea bob.
Whats the best,easiest,quicker, joiner,splitter,tool around?....
the 1 i have.(ASF TOOLS3.1)..makes it more easier & worthwhile...to sit and pause the commercials. -
Virtualdub is easy and free for avi without recompressing.
Click the start frame the end frame and cut the selection. Do it as many times as needed then make sure that video and audio are both set to direct stream copy. Do a "save as" pick a file name and you will get a fully cut file within a very few minutes. It saves at hundreds of frames per sec. If you decide to use filters resize etc... then you would have to recompress in full processing mode but for simple cut and trim it's very fast. -
You have to set the cut points with virtualdub at keyframes or your going to get some parts not cut properly,best way to use virtualdub is to edit and cut all the parts without saving it and them frameserve it.
allow me to re-arrange thatOriginally Posted by andkiich
MMC that comes with the ATI card allows for pausing while recording.
MPC-HC : audio does not pause when video pauses for H264 video
By kswartz in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2011, 02:56 -
Questions Regarding Video Capturing for "Gameplay" Vids
By cdubya in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2010, 19:26 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Picture "rolls" when capturing (video included)
By scully1888 in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2007, 12:52 -
Video is "blocky" when capturing DV via firewire
By kongla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jun 2007, 04:27
