I have tried TMPGenc DVD Autor and DVDLAB for DVD autoring with mixed results.
Are there any othere good DVD authoring apps which do not reencode DVD complient files? I want try something different.
I hate the fact that DVDLAB takes too long, it demux and then remux the same files!
TMPG DVD Author does not seem to do menus in 16:9 ratio only 4:3, with very little flexibility.
Thanks in advance.
I did but the problem is that it creates audio synch problem if I don't. My source files are DVB mpeg files.
Ah - I'm seeing a lot of posts about various Mpeg types.
I think the whole mpeg spec is a little messy and causing difficulty.
Have you tried demuxing and then a simple re- author with IfoEdit.
Try and get a program to check out the streams delay etc. That might give you some clues.... -
Maa the problem is that TMPGenc DVD Author did not have problems with the same files! This app is too simple.
Adobe Encore author without re-encoding. I have been using it for the past 2 months and despite all the crticism I have read about it, I am pleased with it.
No problem to report so far. -
Hi there,
try Ulead DVD Movie Factory 2 ("Filmbrennerei"), it does optionally no reencoding.
HTH
Tomgreetings
tom
DVD authoring without re-encoding
By siluet in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2009, 05:36 -
Which DVD authoring application is good at seamless branching?
By AnitaPeterson in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 22:03 -
Authoring/burning application that supports half-d1?
By sharper in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2007, 16:38 -
Basic Application to create .psd buttons for Authoring?
By Moontrash in forum Authoring (DVD)Replies: 12Last Post: 24th May 2007, 07:12 -
Regarding MPEG2 Encoding (DVD authoring)
By Wuhtzu in forum Video ConversionReplies: 9Last Post: 10th May 2007, 18:07
