It was mentioned a few times in some guides here that VirtualDub doesn't demux AC3 properly and it is necessary to use BeSliced to fix AC3 before using it in DVD author. Is it old (fixed) problem? Do I need to do it with current Vdub version? What about VdubMod?
And also: what is better - to demux AC3 and then use BeSweet to convert it or use avi file as BeSweet input file and convert it directly from avi?
Thanks.
For ease of use I suggest VirtualDubMod for AC3 or any audio demultiplex.
http://virtualdubmod.sf.net
In "Streams" menu, choose Stream list, click on the audio stream and click on Demux button. Right?
https://www.videohelp.com/toolsimages/standardtool332.jpg
Otherwise, try AC3Tool for AC3 convertsion/demultiplex...
http://www.digital-digest.com/dvd/downloads/ac3tool.html
Interesting Build of VirtualDub/Mod
By Soopafresh in forum Video ConversionReplies: 8Last Post: 12th Oct 2012, 00:49 -
Virtualdub Mod and Vobsub woes
By TheLaserdisc in forum Video ConversionReplies: 4Last Post: 30th Dec 2008, 00:03 -
is it possible to crop a WMV file with virtualdub mod?
By sumeshkri in forum EditingReplies: 4Last Post: 13th Nov 2008, 21:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Encoding audio with VirtualDub MOD
By GangstaRap in forum AudioReplies: 5Last Post: 19th May 2007, 07:20
