Hey everyone...
im trying to convert a dat file that i simply copyied from a vcd to my hard disk to watch. now i want to convert the dat file to mpg to burn and put on a dvd or another vcd. ive tried iso buster but that only reads from the vcd in the cd-rom drive. are they any other methods or programs than isobuster.
please help me...
Open ISO Buster, select File, Open Image File. Browse to your .dat file.
Cheers, Jim
My DVDLab Guides -
i tried that the right click on the dat file after opening and click extract-> mp2/mpg only
it saved the file but when i went to my hardrive to check if it worked its file size was 0kb and the file didnt play in media player.
i tried this with three completely diffrent vcd dat files on my pc??
i then tried converting it to a cue file through isobuster...it worked but i dont know what to do with it now
ive done basic dvd rips and mpg conversion but not anything with bin/cue files -
Hi there, when i've got bin/cue files to edit, I use CloneCD or Alcohol to mount it as a virtual drive then use VCDeasy to extract the dat file to mpg. I can play this mpg in Mediaplayer and open it in tmpg if i want to re-encode it. If i've been given multiple bin/cue files for one movie; once i've extracted all the dat's, I use DVD2AVI to "add them together" and create a d2v file to open in tmpg. Hope that's of some help, Typhus
What one man can do, another man can do! -
It's not recommended but you could change the .dat extension to .mpg,most encoders will accept it.
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
