I have all the codecs I needed to view the video. I can view it through Divx Player 2.5 with no problem, and GSpot says Habe all the codecs to view the file. I just want to reduce a little bit the quality. Here's some info on the file:
Video: an AVI, 640x272, 25fps, DIVX 3 Low motion, MPEG-4
Audio: 48000Hz, 5 Channels, Sample Precision 0-bit, Compresion Dolby Digital AC3
With VDub, I tried to preview, and it gave me this message: The Requested audio compression is not compatible with the input format, check that the simpling rate and channel count of the input match those of the requested format.
With TMPGEnc, I tried put in the audio source and it says it cannot be open , or unsupported.
Can you help me
You probably need to install AC3 ACM Decompressor. VirtualDub needs this to be able to work with AC-3 audio.
Good luck.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 21:57 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00
