Results 1 to 15 of 15
  1. Member Sorcerer's Avatar
    Apr 2001
    California
    I've installed my ATI All In Wonder Card in my case, then when I boot up my computer just restarts over and over. Is there something wrong with the card or do I have to upgrade my motherboard maybe. Once I got to install the drivers but everytime it kept re booting itself. Sometime I can finish installing them.
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I had something similar to this, it was faulty memory.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. Member rhegedus's Avatar
    on the jazz
    Is the card seated properly?
    Regards,
    Rob
  4. Member Sorcerer's Avatar
    Apr 2001
    California
    Will
    what do you mean by faulty memory? is it too fast for my computer to handle?
  5. Member Sorcerer's Avatar
    Apr 2001
    California
    yes it is seated properly.
  6. Lost Will Hay's Avatar
    Oct 2002
    Will
    To put it simply; my memory was f*cked.
    EDIT: Hang on, you only have a 450 processor?
    You must have an old motherboard then?
    I'd check in the mb manual if I was you, some of the newer cards need a certain PCI slot type to run.
    I'm no expert but I think it's something to do with the BUS (and I don't mean the No. 77 that takes you disco-dancing on a weekend).
    Will
    Dec 2002
    Cary, NC, USA
    Yes, it's bus mastering or something similar where the card can take over since it does quite a bit to run the TV etc. Such an older system may well not have it, 400 MHz was around the border time for it being there or not..
    And of course there are all your settings in CMOS, they could stand checking since most PCI boards have plenty of minor options.
    Alan
    Mar 2003
    Uranus
    I knew the answer to this once , but
    I have a faulty memory
  9. Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    You might look into this possiblity.
    http://www.pcworld.com/howto/article/0,aid,78044,pg,2,00.asp
    @FOO -- sometimes you're an @ss -- but a pretty funny one
  10. I agree; your system is very old. It also may be an irq conflict. Are you trying to run both video cards at the same time?
  11. Member Sorcerer's Avatar
    Apr 2001
    California
    no just the ati.
  12. Lost Will Hay's Avatar
    Oct 2002
    ....it also may be an irq conflict.
    Time for Blair and Bush then
    Will
  13. Lost Will Hay's Avatar
    Oct 2002
    no just the ati.
    Have you tried re-installing your old card, to make sure it is the ATI?
    That's the only way you'll know for sure.
    Will
  14. Actually some older boards don't work with ati at all.Check your motherboard manual,I had a customer that had a ecs motherboard and It was not hardware compatible.
  15. Member Sorcerer's Avatar
    Apr 2001
    California
    no just the ati.
    Will
    yes i have tried re-installing my old card and it works perfectly. i think it's my motherboard so i'll just upgrade soon.
