file: divx met ac3
ac3 bitrate :448
time :2 hours ,1 minute,12sec.
want to convert to 1 dvd.
i use dvdrhelp bitrate calculator, and i get a bitrate of :4574
so i use 4574 as constant bitrate in mainconcept encoder/video settimgs....after 2 hours i get a file as big as 5,,2 gb.
what did i do wrong , need i another setting with ac3
or what went wrong???
Hmm, dunno. Your figures look right to me and the dvdrhelp bitrate calculator has never let me down.
Maybe MainConcept didn't correctly keep the bitrate at what you requested. Maybe one app thinks a kbyte is 1000 bytes, the other thinks it is 1024!! Maybe it was full moon
Anyway, open your mpeg in bitrate viewer to see what the actual bitrate is. This might help to track down where things have gone wrong. -
Working it out manually, I get a similar figure (4645kbps). I think this bitrate that the calculator is giving may include audio and overheads. By my workings, your video only should have a bitrate of 4197kbps. I assumed a DVD holds 4250MB, and you are keeping the 448kbps AC3.
Hope this helps,
CobraDMX -
If you are using LPCM you must calculate with 1536 kbit/s for the audio.
but you can replace the lpcm audio with the smaller ac3 audio,
https://www.videohelp.com/guides.php?guideid=447&howtoselect=4;10#447 (skip the tmpgenc encoding part) -
how much have a to calculate for: mpeg1 layer2 ????
what is the bitrate....by the way thanks for all the help -
Try using a variable bit rate as opposed to constant. This should free up more room for you on the disc.
Willing To Learn
WinX DVD Ripper Platinum Ripping at Wrong Bitrate
By wperry1 in forum DVD RippingReplies: 14Last Post: 15th May 2015, 13:05 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Bitrate calcultor for HDV to MPG2 DVD specs needed.
By beammeup in forum Video ConversionReplies: 6Last Post: 14th Sep 2011, 11:09 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
DVDrHelp.com not working
By gadgetguy in forum FeedbackReplies: 3Last Post: 1st Nov 2007, 10:05
