I just got an AIW card from ebay (it's the first gen. radeon AIW). The problem is that I can't get sound - the card did not come with the breakout box so I got another one from ebay.. I noticed that some break out boxes have a line out minijack that needs to be hooked up to my soundcard while the BOB that I got does not - is this the problem? Is there a way to work around this?
Thanks!
if you have an extra analog cable like the one going from your cd drive to your sound card you can loop your cd through the aiw (cd in) and then to your sound card (cd out). it would be easier though if you had the cable with the mini plug. after you get the cables set up you will have to open mmc and run the initialization wizard and make sure you have the sound set up right (i.e. Cd in, line in , microphone...)
good luck!Donadagohvi (Cherokee for "Until we meet again")
ATSC tuner card that captures surround sound
By Theophilus in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2011, 07:50 -
no sound in DV captures
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 6th Jan 2010, 13:59 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 21:53 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 19:36
