i have been dolading movies from the net, and have been encoding them using neodvd 5, i them use nero to burn them onto disc but when i view them on my dvd player the movie jumps and also the qulity isnt as good as the downloaded avi, mpeg file.
can anyone tell me how to avoid the movie jumpig and retain the high quality of the 700mb avi, mpg file??
Cheers![]()
1st, tell what format the avi's are (divx, xvid, resolution, framerate, audio format etc).
Then tell me what format you want to convert them to (DVD, VCD, SVCD, XVCD, PAL/NTSC etc)
then I may be able to help.
But I still suggest reading a few guides as a damn good starting point, and quicker than waiting for someone to hold your hand through the whole process. -
700 MB full length movie is the problem. You are downloading something based on a disk size and not on any quality setting. The best you can hope for is VCD quality.
Assuming you don't live in the US and what you are downloading is legal (implying there are no legal 700 MB AVI downloads in the US, and there aren't), try bigger movies.
1400 MB AVI's (in 2 pieces no less :P ) are close to DVD quality (for short movies). 2100 MB AVI's are usually DVD quality and typically include an AC3 soundtrack.
It's much, much easier to work from an original DVD than to work from some unknown AVI. Never, ever assume the person that encoded it knew what they were doing. Converting AVI to MPEG2 to DVD requires a lot more tools that converting a DVD to an AVI.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Combining synched sound with video - total absolute newbie
By Povster in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 16:37 -
Total newbie needs help urgently (AVDHC -> DVD, with complications)!
By sebkni in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2010, 13:11 -
Total Newbie- Need help Premiere Elements 4- Two cameras Rendering
By VitalExpressions in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 21:53 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 11:28 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 12:24
