Greetings.
Is there any software, preferrably freeware that can capture DV and split the file if it is over 2GB in size, until it finishes the entire capture and then be able to burn to DVD?
TIA
Take Care.
JuanMa -
I dont know any one that can do complete thing but for capturing u can try this ScenalyzerLive
https://www.videohelp.com/tools?tool=50#comments -
Originally Posted by redwudz
Thank you redwudz and mrmungus.
I will give it a try.--
Take Care.
JuanMa -
Greetings.
I have been using WinDV so far without problems, the program is awesome!
I switched from Win98SE to XP with NTFS, so it works even faster, the only thing is that I have no idea as to how to change WinDV to just make one avi file under NTFS.
Any help, will be appreciated.
TIA--
Take Care.
JuanMa
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
