I need to convert movie.avi(102min) file to movie.mpg(MPEG-2) and split this big file using one step(encoding).
Any program can provide this future?
I need to decrease my time for creating SVCD.
Thanks in advance,
Sorry for bad English.
<font size=-1>[ This Message was edited by: Mr.S on 2001-10-19 17:22:59 ]</font>
I am not sure what you are trying to do, but I have a suggestion for you. Try to post using a more meaningful topic - that is something other than "Can you help me". Many people just look at the topic to get the idea and that topic gives NO IDEA what the problem is. Good luck.
Ummm Gunther. I have this weird problem. Can you help me?
Haha...Good point though. -
TMPGEnc. http://www.vcdhelp.com/tmpgenc.htm
Use the source range, define the start and end frame of the first part, save the project. Repeat with the 2nd part. Open batch encode, add these 2 projects to the batch encode list and run.
How to use source range: http://www.vcdhelp.com/DVDConversionGuidev1.3/dvdtovcd2.html#TMPGEnc -
Thank you Truman for the framming tips.
For information (very good DVD Player):
http://www.sampoamericas.com/products/dve631CFSpecs.html
MPG output file:
MPEG-2 720x480 29.97fps CBR 2496kbps, Layer-2 44100Hz 224kbps
<font size=-1>[ This Message was edited by: Mr.S on 2001-10-19 18:12:06 ]</font>
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00
