All of a sudden for some reason, my D; drive is not responding when I put a disk in, and even when I go to my computer and try to open the drive it won't let me, it pops up a window saying... "Unable to access drive D: the drive is locked by a disk utility" What in the world does this mean, and how can I fix it??? The drive is my dvd drive so I can't even watch any moviesHelp would be much appreciated!
oops, sorry, didn't mean to post this ? under this forum...
no problem .. it has been moved for you
Mod Offline -
can you find solution for this same thing is happening with me too.Please reply back.
Thanks -
just a wild guess....but have you changed the playback region at all?
not sure what you mean? can you tell me how to check...thanksOriginally Posted by richdvd
Right click on your drive....Properties...Hardware tab....Select your drive...properties....DVD Region tab....it if is normal, it should say "Changes Remaining:4". I doubt this is the problem though, if you've never changed it.
I have heard of this problem before but never seen a solution. I have never had the chance to see it myself - no chance of you shipping your PC to me is there?
Have you tried going to control panel, system, hardware manager
and click on cdrom drive and remove - then reboot ??
"Hide" field locked in Subtitle Workshop
By neuroxik in forum SubtitleReplies: 0Last Post: 17th Aug 2011, 03:08 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Need help: Trouble importing/capturing a "locked IFO" on DVD
By mattday79 in forum Video ConversionReplies: 3Last Post: 1st Jan 2011, 18:29 -
By mattday79 in forum Capturing and VCRReplies: 3Last Post: 1st Jan 2011, 14:41 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27
