    Nov 2003
    Ohio (US)
    i did a quick search of the help and forum and didnt find an answer.
    i have a bunch of home movies each from 30 sec to 10 mins. i want to put them onto a dvd each as a chapter with a link to each one on the menu. but i want them to play continuous with a simple transition between each one. is this possible in tda?
  2. TDA does not have selectable transition features or menus.
  3. You could build in the transitions with Windows Movie Maker 2, then just do a standard author with TDA.
