I just got myself a dvdr 75, and have copied a few movies from vhs on it to DVD+RW, I never finalised the disk, and ripped it to the HD with dvd decryptor using file mode, I then used tmpg author to redo my own menu, does this method completely remove the philips menu, it doesn't come up when played on a dvd, byt is it hidden somewhere in the structure still.
How do all the other philips lads remove the menu and put them onto there comp to edit.....?
Any tips for a newbie.![]()
when you include your vob files in TMPG DVD author, you only include your videopart, no menu will be read into the program. The philips menu
will not be used.
After making menu's and generating the new vob files, you can burn
a video-dvd with them. Only the new menu's will be on that dvd then. -
Is it better to extract using file mode than ifo mode??
Any decent guides for dvd standalone editing stuff on a pc. -
extract? you simple use your windows explorer to copy all files in the video_ts folder to your pc. no ripping needed.
I stick my RW disc from my Philips into Ulead Movie Factory 2 . I then use it's "Edit Disc" function to replace the Philips menu RIGHT ON THE RW DISC....no need for ripping. The contents of the disc never touch my hard drive.Originally Posted by Growler
Pretty silly to do it to a disc with just a movie....but with something like music video compilations?....GREAT tool.
It works best with 1 hour (HQ) mode discs though....sometimes stumbles on 2 hour discs....but not always.
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum Capturing and VCRReplies: 11Last Post: 23rd Aug 2012, 12:19 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
dvd stuck in dvd player - best removal technique?
By ChaunceyK in forum Off topicReplies: 9Last Post: 22nd Mar 2010, 21:07 -
Philips DVDR3475/37 Menu Scene screen
By dblan9 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Mar 2008, 15:53 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
