when i choose to simulate a burn in nero 6.3.0.2 it runs a simulation but actually does a burn and not a test. a message pops up that says simulation successful but when i go to burn, nero has already burned the video on the simulation run. is this a bug or what can i do to fix this problem
I'm having the identical problem. No Pun Intended but doesn't it just "Burn" you.
I was testing + and - R's at various speeds and made 6 coasters before I knew it. I aborted each simulation after I felt sure it was going to pass rather then sit through the entire process. -
Originally Posted by ted york
No it's not. The simulation isn't supposed to write anything to the disc. The burn does and when cancelled what has been burned remains.
I found that I had a faulty power supply that was intermittently turning off but almost immediately back on. I wonder if this screwed something up. i would assume that the laser whether burning or simulating needs a decently regulated power supply.
If I find out anything more I'll be sure and let you know. Right now I'm a little hesitant to try any additional simulations just to see what happens.
LOL - Ted
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
