I have been converting some of our vhs tapes to dvd and seem to have a problem with audio dropping out. I use a panasonic e50 to capture to dvd-ram. I then copy to my hard drive on my pc and use dvd-lab to author and Gear to burn it. It works in every dvd player I have, but I have sections on the video where the audio will drop out completely for a second and then play fine again. I use Ritek G04 media. Any suggestions on what this could be from. Should I try burning with different software? Any help is appreciated.
Ron
By the way, I have no audio dropouts when playing back from the dvd-ram. It has to be somewhere in the authoring or burning process. I am upgrading my memory from 256 to 512. Could only having 256mb of memory cause any problems? If anyone can recommend dvd burning software that might be better than Gear, please let me know.
Ron
Best way to mask dropouts on old Betamax recordings?
By baakre in forum RestorationReplies: 27Last Post: 31st Mar 2013, 10:21 -
Repeated VHS Dropouts
By NitroPress in forum Capturing and VCRReplies: 2Last Post: 3rd Mar 2011, 09:03 -
Audio dropouts when capturing a particular Digital8 tape to DV
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 4th Aug 2009, 19:18 -
MKV Audio Dropouts
By hcour in forum AudioReplies: 2Last Post: 12th Nov 2008, 09:09 -
Panasonic DVD recorder & timecode breaks / audio dropouts
By webstar in forum DVD & Blu-ray RecordersReplies: 8Last Post: 23rd Jul 2007, 17:43
