  1. http://www.newegg.com/app/viewproduct.asp?DEPA=1&submit=Go&description=ritek
    Model#: DRD-47-4X-RDSM
    Item#: N82E16817132315
    $48.99
    Model#: DRD-47-4X-RD-IW
    Item#: N82E16817132302
    $52.99
    I was wondering if anyone can tell me the difference from these two? From the description they seem the same?
    Thanks.
  2. If those pictures are accurate, the more expensive discs look like they're white-top. The 'IW' in the product code maybe Inkjet Writable.
    That's my guess...
  3. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    That's my guess...
    That's correct, I just ordered 2 packs of the ones for $48.99 and they were the "Silver Matte" finish. But if you read the 1 and only review that the ones for $52.99 have:
    These are excellent 4x Riteks and Burn perfectly in my Sony 510a Burner with no coasters and I am a third way thru my first pack of 50. I think these are the same 4x -R as the other Riteks here that has 22 reviews except these are the whitetops that can be printed...which I plan to get an epson and print these tops directly since I dont like labels.
    You can see that those are the Inkjet printables.
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
