Hi all,
I'm trying to use Nero recode for mp4 transcoding of videos I've recorded with my Hauppauge PVR250 (.mpg format). I'd like to do this without creating the entire DVD structure. Is this possible? Is there a way to convert mpg files with mp2 audio into vob files without any recoding?
Thanks,
wade
If you want it to play as a DVD, then it must have the DVD structure.
If you are lucky, you might find a DVD player that can play MPG2 files directly, but other than that, you must author. -
Demux mpg into it's primary streams. Then use IFOEDIT's "DVD author option to create the DVD file structure. You not actually encodeing anything,just createing the file structure,tales a few minutes. IFOEDIT makes no checks for DVD compliance so mpg stream should work. The directory it creates should open in Nero Recode. I've converted SVCD's to DVD this way and that works.
Resequence VOB without re-authoring
By bluetoonboy1 in forum DVD RippingReplies: 8Last Post: 12th Jun 2011, 20:12 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
AVI to MPG for authoring?
By chronic777 in forum Video ConversionReplies: 2Last Post: 25th Sep 2008, 11:43 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 09:27 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
