i have an avi file..
never had to mess with an avi file so im a little confused here
ive looked around at some guides and forums to figure out avi
i just want to know if i can burn my avi file to dvd and it play on my dvd player? i tried opening it in my dvd burning program which is sonic my dvd and it says that i am trying to burn a pal version? and need to change my settings to that?
should i convert my avi file to mpeg2 or ?
ive tried opening it in tmpegnc but it says it cant support that kind of file
so im quite confused on what step i do next with this avi file
any help please
I think you should check www.lordsmurf.com for descriptions of what avi files really are, when and when not to convert to mpeg2, PAL vs NTSC, etc.
All useful information and not terribly time-consuming. If you're in the USA, I don't think you want PAL version. -
Go to the 'Tools' section to the left and download Avicodec or Gspot. These programs can identify what type of AVI file you have, whether it's PAL and things like framerate, size, etc. There a quite a few types of AVI's. If you have the proper codec you can convert it to MPG2 and burn it to DVD after processing and encoding.
Avi and avchd to DVD - 2 questions in 1
By merovingio in forum Video ConversionReplies: 1Last Post: 15th Oct 2011, 12:22 -
AVI to DVD Questions
By RdM642 in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 21:30 -
Unanswered questions on processing and compressing DV-AVI
By sd_smoker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 40Last Post: 2nd Jul 2008, 16:31 -
A few avi splitting questions
By Daniel90 in forum EditingReplies: 1Last Post: 15th Oct 2007, 08:10 -
A few questions on creating AVI's
By Sober in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2007, 05:09
