What exactly is HD-BURN?
The reason I'm asking is because I use CopyToDvd to burn my dvd backups and it has an option to support HD-Burn and its checked by default. I don't know what it does but I'd like to find out. The CopyToDvd help file says nothing about it.
Thanks for the help.
btw, sorry if this is in the wrong forum, I didn't know where else to post it.
^^Thats a picture of the CopyToDvd settings.
Results 1 to 10 of 10
When was that article written? Just wondering how long before this is in general use and firmware upgrades are available. Could a similar process apply to DVD?
It works with Sanyo-Optorite burners.
Another link
http://www.cdfreaks.com/article/118/3
Of course, its called Blue Ray...Could a similar process apply to DVD?
It's a fantastic technology, and about as useless as Sony's DD-CD format. Nothing like a disc that only works in the burner you burned it on.
.indolikaa.
I have HD-Burn
BFD -
. But they are going to licence this technology to other major mfrs (ho-hum). Do these disks even work in sanyo dvd players??Originally Posted by indolikaaCorned beef is now made to a higher standard than at any time in history.
Well supposedly there was glory and fame for this format, since a simple firmware update to a DVD player would make HD-Burn work. But methinks Sanyo may have been asking for a steep royalty, since I haven't seen it listed on any of the newer machines...
Don't know about Sanyo DVD players, though. -
HD-Burn is a CD-R technology.
I haven't seen it migrate to CD-RW yet, though Sanyo claims this is coming soon to 24X CD-RW. And, because of it's design purpose (to fill the gap between 700MB CDs and 1.85GB DVD-3 and 4.7GB DVD-5) and physical parameters it's not for DVD. -
Is there a way find out if my CD burner supports HD-Burn? A list perhaps?
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
