I am a newbie and I was recording a TV show with my AIW video card. I am capturing in mpeg-1 format.
I'd like to covert to DVD (mpeg -2) I think...
What software do I need?
thanks,
Mattlock (newbie)
You dont need to convert or re-encode mpg1 for dvd,Tmpgenc dvd author is what you need.
The DVD format supports MPEG1 video. There's some debate about the supported resolution (only 352x240 or 720x480/352x480/352x240) but most people seem able to play MPEG1 video at any DVD resolution.
The DVD standard as a max supported MPEG1 bitrate that's rather low (IIRC ~4000kbit/s) but again many players can handle higher bitrates.
So if you're video is at a supported resolution with 48khz audio you're pretty much good to go. -
Originally Posted by Vejita-sama
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 00:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 22:36
