I know well enough about picture formats and how to make them lossless, and same thing with audio, you have an Audio CD with uncompressed WAV files that you can rip and compress to lossless codecs.
But how is lossless progressing on videos? I assume that there are a lot of other things to consider such as frames per second and resolution.
Anyway, I was thinking of getting a TV Tuner in a few weeks. And I was also hoping to record some shows. Is there a standard resolution that cable TV comes in that will be used when making the video file? And is there a way to capture that file in a raw uncompressed format and then convert it to a lossless video format and FLAC audio for example? Basically, I'd like to have a copy of the video in the exact quality and resolution it was broadcast in.
Is it even practical to do it like this? I know that if I want to watch it on my DVD player, I'll have to convert to MPEG2, and that's a lossy format, correct? How much of a difference is there in quality?
Thanks, and sorry for the really newbie quesitons![]()
It's not. The whole purpose of the Motion Picture Experts Group was to deal with this very issue. Uncompressed .avi files run about 60 GB per hour.Originally Posted by tgc225
Well, traditional analog cable is 336x480. Digital cable is at the mercy of whatever front-end encoding scheme is being utilized.Originally Posted by tgc225
You could capture with huffyuv. That would get you down to about 25 GB per hour.Originally Posted by tgc225
No. That's why MPEG was developed.Originally Posted by tgc225
Try this: 704x480 @ 8000 CBR (1I1P1B encoding) with LPCM audio. You won't get much on a DVD but this puts your overall bitrate at 9.5 Mb/s. Compare it to the uncompressed.avi file it was created from.Originally Posted by tgc225 -
Thanks a lot for your in-depth post! So I guess lossless video won't be popular for a while at 25gb an hour
Anyway, is that "704x480 @ 8000 CBR (1I1P1B encoding)" for the MPEG2 format? Is that the recommended format for highest quality?
By the way, is there any website that goes over every popular digital video format? -
You're welcome.
The best information on digital video I ever found was at lordsmurf.com. Not an in-depth analysis, but enough to understand why TMPGEnc has the settings it has. I've also learned a lot from this forum, but I do troll twice a day and read a lot of posts.
The 60 and 25 GB figures are estimates, I could be off on those a little. It's been awhile since I've captured uncompressed .avi files.
Question about 1080i and 720p formats
By mr-scarface in forum Newbie / General discussionsReplies: 26Last Post: 11th Mar 2011, 00:18 -
Newbie question about joining videos in different formats
By bobrov in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2010, 05:51 -
A question about lossless audio formats.
By mpalm887 in forum AudioReplies: 11Last Post: 31st May 2009, 21:34 -
Question about 360 streaming formats
By nfl2k2 in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th Nov 2008, 08:18 -
Question about video formats compatible with Philips DVP5140
By cooper101 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2007, 17:36
